Spring Swap
Snowman269
MN
I see one person did or may have done the "A Codes" IMHO I would not do that. A Codes would need Air bags for towing for certain. Heck just my family loading the X for vacation the B's are borderline not enough. For towing I level with the air bags. When I did the B Codes, F's were not known about, but if they were, that's what I would have done. I'm a bit of a perfectionist, & F's are closer to the ideal setup.
V & B's with a 4" block from an F350 works well. V's & F's even better.
Just changing these Excursion's to the way they should have came from the factory.
Snowman269
MN
I'd start with F Codes in the rear improving ride & handling, & then once you get the rear where you want it, then you could decide on the front height. Being you are already lifted you may not need to touch the front. The D front spring would be fine with a hanger kit, since they won't bottom any more.
PSD POWER007
Columbus,GA
Yeah, I was just wanting to improve the handling and towing capabilities. Do away with the possible sagging in the future also. I don't mind if a spring combo will give me additional lift as long as the combo lifts the front and rear about the same.
