Truck died while driving and wont start!! Help please!!
clintusaf
Clint
Bossier City
Guys i need help quick. Im tdy in wichita falls texas and just went out to get a carwash. As i was exiting, i noticed i had no power steering (had the radio up). I pull over and try to restart and it just cranks and cranks. I have no abnormal dash lights. What do i do?
CPS?
If not that, maybe you got water in your IDM? My bet would be on the CPS...
clintusaf
Clint
Bossier City
Okay. I was going to get a cps for just a situation like this, but never got around to it. How do i tell for sure?
6.0PSD777
Mass
Not sure how to test but def sounds like it, everyone i know with a 7.3 carry's 1 or 2 with them...
if the tach doesn't move when cranking, CPS
if no "Wait to Start" light, check the #30 fuse in the dash..
if it pops as soon as you hit the key, unplug the fuel bowl heater.
if it still blows, your IDM got wet, shorted out and you're hosed...
clintusaf
Clint
Bossier City
if it still blows, your IDM got wet and shorted out.[/QUOTE
i do have the wait to start light. No rpms when cranking.
What do you mean if it pops when you hit the key?
IHC Power
STOCK STROKE
Walpole Mass
Cps
If your sensor is black and the bracket is gold then your truck is still running the older recalled cam position sensor, it should be a silver bracket with a grey sensor, the updated one. JL means if the fuse blows....
hes referring to the fuse popping again..which means your fuel bowl heater is bad.
as far as the rpm's when cranking...you wont see that cause your tach read's 0 until the motor is running...i think they switched over to this style in '02.
yep...no sure fire way to test the cps. just go buy one and replace it and see how it goes...
you'll need a 10mm socket and a little oil to coat the new o-ring.
and tomorrow, stop by a custom bootmaker named Guy Spikes and say Hi..
he's married to one of my cousins..
