7.3 PSD wont start
94f450sd
certified nutjob
plymouth,ma
where do you live?some of us do have code readers that work on these trucks.depending where you live one of us may be close to you and come give you a hand.i do free code reading for members.
blueox
Sanford,NC
I live in Sanford,NC. I talked to a buddy of mine yesterday and he knows of someone with a reader and is supposed to find out something for me today.We were even talking about buying one if it came down to it.Not sure of which one to get if we did?
blueox
Sanford,NC
yup checked it twice since we've been crankin on it so much.Full both times to the bottom of the plug.
Still looking for a code reader here locally through a few people.
Just make sure your code reader can read CAN as Ford uses CAN for communications to the port.
Dave :)
blueox
Sanford,NC
Probaly 2 1/2hrs ? Im between Raleigh and Fayettville.Think im gonna just take it in tomorrow to a shop as this truck has to be on the job daily.When i find out i'll be sure to let you guys know.
blueox
Sanford,NC
I think i have the wrong cps? Dealership gave me F7TZ-12k073-A and from what ive seen thats for a 97-up. Mine should be #F6T0-12K073-A for a 96.It was built 11/95. Could this be the problem? I just read another thread that says almost the same thing which got me checking the part numbers and three diffrent sites have the first one listed for 97-up psd.
Wanted to see what you guys thought before i had to go buy another cps (doubt they'll take the other one back)
OK,
Here are the PN#'s for the CPS and you can see there is a difference between the years. However, a CPS that is for a 97 will function just fine in a 96. The only difference between the two is what the pin material is made of. Some say using a CPS for the wrong year can lead to corrosion between the two different metallurgys. But as far as function goes, they are interchangable.
(Ford) F6TZ-12K073-A 94-96
(Ford) F7TZ-12K073-A 97+
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
