how much boost???
96EDGEpsd
Welding/Fabrication
New York
yea i started with hard tubing with compressions, then when i kicked that i got that bigger stuff, its not too soft...65psi rated...damn i wish they sent me one of those, that looks more alot better...im deff ordering one of them!!! is there any way i can temporarly fix it?
you guys are awsome!!! thanks a ton
whatabudro
Launched
You don't need the boost releif valve to fix the problem, I was just showing what the fitting looks like. Here is what you would use if you just spliced into the line with a "T" :
97CREWCABPSD
Smoke What Smoke Officer?
Salem, OR
im having similar problems i can only make 18-19 lbs of boost and by my sig you can see that im fairly modified. any suggestions?
96EDGEpsd
Welding/Fabrication
New York
i duno i cant figure it out, my trucks making normal boost, it just wont show up on the gauge, i tested the gauge with my air compressor, it works fine...grr idk
whatabudro
Launched
Is the pyro pre turbo ( in the exhaust manifold) or post pyro (in the down pipe) ?
JOAT
I Found Nemo!
The West Coast
Have you ran it with the MAP sensor wiring connector unplugged yet? If the PCM does not see enough boost it will not increase fueling. Unplugged, the PCM will assume a programmed default MAP signal. Also make sure your MAP sensor is grey, not black.
