I mounted my Vegtherm like hheynow did...works really good.
On top of the filter, where the cover used to go, there are those two bolts sticking up...use the P clips on that to hold the vegtherm. I probably have a 5 inch run of 30r9 from the end of the vegtherm to the pump...
Purging the coolant loop shouldn't be a problem...just let it run, and fill up the radiator periodically...air will work itself out of that line no problem.
I made a lucky mistake that purged my WVO line. Remember I had pinched the vent hose when lifting my tank up? I started in the morning, and as the temp raised, the pressure in the tank built up. it started squirting fuel out as I was running the plumbing...so as I ran the hose, it went ahead & filled itself! Since you did a looped return, it's a bit more difficult to purge air from that line. What you'll have to do is run it for a while, and switch between tanks every 30 seconds or so. That will push the air back to the diesel tank.
Run it on VO and disconnect the return line right before the tee to bleed out any air then reconnect and re-check fuel pressure. Better yet, get a 1/4" female tee with 3/8" hose barbs on each end and a mini ball valve in the middle. This can be installed in the return loop as an easy means to bleed off any air since it's a closed system.
