Slight Vibration at take-off
DragonSlayer
Pensacola FL
my truck shuddered at hard take off until i had some recall done about drivability, after that no more vibration. my truck is stock height and stock tires, and 36,500 miles on the odo.
fastmike926
Ford has 2 TSB's for this problem. If you have a 2 piece driveshaft the carrier bearing needs shimmed, if a 1 piece driveshaft there are a couple of options with the rear blocks. This is really common on Crew cab shortbeds.
dealer6
pharr,tx
Kleetus said:
Not sure what to tell ya, but I have one at 20 and 40 mph, and it vibrates alot from takeoff with a decent load behind you. They keep telling me it 's the tires, and I keep telling them I can replicate it without tires on jackstands. Ford rep is supposed to come out next week with an analyzer of some kind. They want me to bring a load...
my truck is doing the samething as you guys are describing, i have a 6" lift and 35's, it just started doing this about a month ago, mine does it from take off and going down the highway around 65 mph, if i put it in tow/haul mode it doesn't do it highway speed but still does it at take off, any ideas??
karla06
It is the carrier bearing and as someone mentioned above, there is a kit that solves the problem. Really don't think it is the tranny. Lucky for you.
Kleetus
Butler PA
Yeah, I keep telling Ford that and those retards keep looking at the tires...
Mark Oomkes
The morons at the dealership where I bought mine tried reflashing to make mine go away. Needless to say, I haven't been back to them for service. Other dealer tried the shims and greatly reduced the vibration, but it's still there.
Kleetus
Butler PA
I just talked to the tech, and they are looking at changing the driveshaft completely, but they were hoping to get another truck in that had the same shaft to just swap out and check against. They don't want to buy a shaft if they don't need to, which I can understand.
dealer6
pharr,tx
my carrier bearing has already been shimed, even replaced it, still does the same thing, the ford dealer down here told me putting the rear stabilizer back on might help, haven't tried that yet
Kleetus
Butler PA
I don't know that it's the bearing, but the short shaft. That thing wobbles like a bent stick...
dealer6
pharr,tx
i took my rear axle off to relpace a bent rear spring, i didn't mark the ds when i took it off, could i have put it back on in a different position that could make the ds off balance??? i don't know just a though
